Triple layered satin handjob
satinfetish45
Post by satinfetish45 »
I like to get 3 satin items ie pj bottoms,nighties,skirts, I put on one on normal on one inside out then the third on normal. The glide you get when you rub your cock is unreal. If you are a fan of satin try this I can garrenty you will make a mess In less than a minute. Also try humping your mattress it feel great.
SatinBeard
Re: Triple layered satin handjob
Post by SatinBeard »
satinfetish45 wrote: Mon Nov 28, 2022 7:25 am I like to get 3 satin items ie pj bottoms,nighties,skirts, I put on one on normal on one inside out then the third on normal. The glide you get when you rub your cock is unreal. If you are a fan of satin try this I can garrenty you will make a mess In less than a minute. Also try humping your mattress it feel great.
I do this a lot
