Bed set
Re: Bed set
Its not the exact same set, but if you're looking for 100% silk bedding I can only highly recommend these folks:
http://www.ailisilk.com/c/100-silk-bedding_0118/2.html
They also do custom work, I've had them tailor make underwear and clothing (spent probably over USD 10k over the years) and can attest that their silks, especially in the heavier weights (30mm on up), are top quality and will last forever if you take care of them.
