who loves wet messy satin sheets
- Contact:
Its been a long time since I posted here just wanted to say hi
- Satinloverz
- Contact:
Re: who loves wet messy satin sheets
I don't like messy Satin sheets cuz I usually end up sleeping in the wet spots.
Good to see you back on the forum and up to some messy business.
Only problem with wet sheets is that unless you get them washed pdq they can become stiff and stained.
I find that a gentle soak and hand wash in the bath with satin detergent is great - works well on the sheets too !
A rinse and conditioner in the washing machine and then iron whilst they are still just damp.
If it is good quality satin they just softer and softer.
I absolutely love wet and messy satin sheets - it's so much fun!
