Silk scarfs?
satinwifefun
Silk scarfs?
Post by satinwifefun »
Do you like using silk scarfs to masturbate with?
satinslider
Re: Silk scarfs?
Post by satinslider »
YEA! AND THIS HELPS ALSO!!
quibble
Re: Silk scarfs?
Post by quibble »
satinslider wrote: Tue Aug 21, 2018 7:40 am Image
Love that picture
satinslider
Re: Silk scarfs?
TomThompson
Re: Silk scarfs?
Post by TomThompson »
Why yes, yes I do.
SilkScarfLover
Re: Silk scarfs?
Post by SilkScarfLover »
I've used silk scarves for masturbation for years now - absolutely adore them. It's even more exciting to use the odd designer expensive silk scarf for it - the thrill of using something like that in a way it isn't meant to be - and then stained as a result. Can never have too many silk scarves...
