I did this awhile ago and thought to make an updated tips on finding satin goodies on YouTube to watch and have a jooley good time with. Also thought that if you have other ways to find satin on YouTube that I don't mention here, please share as well so we all can get a better enjoyment of satin none porn videos.
The most obvious way to find satin videos on YouTube is simply search for satin or silk straight up but whilst that is the most direct way it's often not the best. It's not the best cause satin is so general of a term that there is a million things attached to satin that is nothing to do with clothing. You can get songs with satin in its lyrics, satin finish on a car or even weapons. So to make sure you don't get those none clothing videos I do these searches...
satin fashion
satin clothes
satin clothing
Now if you have a particular fetish for satin in a item/form then just add that to satin like...
satin dress
satin blouse
satin panties
and so on...
Now there is some ways to find satin goodies without actually searching for it directly like...
try on hauls, look books, fashion shows which can find awesome satin goodies.
This is one with a girl in a satin dress and satin skirt, without searching for satin directly...
https://www.youtube.com/watch?v=UUiqLEjJ3Oc
Then you can look up satin in other languages which can give you awesome results that would not be found by searching for satin in English. Like this by searching for satin fashion in Russian using Google translate...
https://www.youtube.com/watch?v=gy303aEW_Jw
Sometimes I find satin goodies by accident and I love it cause its a sexy surprise which is even a more of a turn on, like how I found these videos...
https://www.youtube.com/watch?v=C3bYb0O4KZA
https://www.youtube.com/watch?v=c4GUR5H5xDs
or you can look up movies that you either know has satin in it or you find sexy that happens to have satin in it without you knowing, like I did with this movie which has a lot of sating in it...
https://www.youtube.com/watch?v=SMjIv-x-C3Q
So there is so many ways to find satin goodies without directly searching for it, what are the ways you find them?
end of transmission...
Roda SaTiN Stein
Tips on Finding Satin/Silk on YouTube....
Re: Tips on Finding Satin/Silk on YouTube....
Don't forget words like silk, silky, shiny - and specific things like pajamas, bed, panty. Also, vintage - there seems to be far more satin in 1980s / 1990s / 2000s content than current.
https://www.youtube.com/watch?v=1JFtq553xKI
https://www.youtube.com/watch?v=8z5seYgfq1w
https://www.youtube.com/watch?v=sesu8l9w1dQ
Most searches we do on Google or your choice of search engine are usually a boolean search which we can use a set of operators that can help narrow down a broad search. For example, when you search satin sheets, the data presented to you usually will be ordered whatever it can find matching the total search entry, then begin to rely on a true/false for each individual word so it will eventually show results for satin or sheets but not both. Sometimes that is what you don't want to see. Well, knowing this forum, maybe the first one, but we want the total result. Using quotation marks on either side of the entry, forces the search to find instances for the exact phrase.
For example: "Satin sheets" -jeanne if you want to find all the videos of that minus the country song and covers that mention her name. You may need to add additional operators to really narrow down your search.
- We can use AND to add an additional variable "satin sheets" AND "fucked" to find results with both.
- OR operates similarly, but it's "satin sheets" OR "fucked" and you'll end up with results with one or the other but not both in some instances.
- We can also make the search more complex using parentheses: "Satin sheets" AND ("Fucked" OR "Pounded"). Now we have created a search that has to have Satin sheets in it and either fucked or pounded.
- One other tip with boolean search is we want to exclude a specific search term: "Satin sheets" NOT "Jeanne"
If it has genitals on the outside it’s hiding something on the inside. -Karen Walker
There used to be up to a month ago, A person called Marinc Bilich I think that was the name? I can't remember the exact name it wasn't a name I could remember to easily!. Who got taken off YouTube because of constant copyright issues they got into a lot trouble with YouTube and had to delete all there clips and account . They must of had hundreds and thousands of clips about satin like from series like Dynasty, Payton place Nots landing etc etc etc. Does anyone know who I am meaning??
