Has anyone bought a cherlone dress? They're really cheap, but wondering if the satin is cheap too, or if they're a good deal?
Any idea anyone?
Thanks!
Cherlone Dresses
Re: Cherlone Dresses
I am in the same mind as you over these dresses, I guess the only way to try them is buy a very cheap one and see what the quality is like. The only trouble with buying off the internet is checking the photo's, it's difficult to tell if the satin is good or not, to give you an example crepe satin takes a very good glossy photo but the material itself is rubbish.
Hi, I've got one.
Personally, I don't think it's actually satin. If it is then it must be a different kind to everything else I have.
For what I paid it's not without any appeal but it doesn't have the satin feel I am used to.
