Where is the best place to buy satin bedding in the UK? I don't want to spend a fortune but equally not interested in a cheap set.
Thanks!
UK Satin Bedding
Re: UK Satin Bedding
Sad to say that a diligent search has failed to find any really good quality satin sheet outlets in the UK; it is all just thin polyester which really fails to last.
Any satin needs to be at least 320 gm / metre in weight which means that the only way that I have found is to buy the material from a good market or shop and have the sheets made up as a bespoke set.
The width of material also needs to be at least 150 cms. In this way a god tailor or seamstress can produce exactly what you want and it will last a lot longer that polyester stuff.
Expensive, probably yes, but at least you can choose the colour and quality and know it has been professionally made.
Good luck !
Good luck !
