satin during sex
satin during sex
i ve a problem when there s satin envolved in sex i lose control and orgasm too early. So i use it only for fore play and remove it when i start. During sex i explode just by seeing touching or hearing its swish. Have u any solution. It s because i m deprived of its fun.thanx
Re: satin during sex
try some long lasting treatment, some spray on your thingy, some apply.
You need to slow down your mind. Start practice playing without satin, don't even think of it. Once you last longer that way then proceed to thinking of satin, then touching it and so on. Will take a while to train your mind but you'll get there. Good luck.
thanx for ur advice but i can t give up satin anyway i want not to be deprived of its shine
Do more workout, eat healthy, the fitter you are, the longer you last.soochasatin wrote:thanx for ur advice but i can t give up satin anyway i want not to be deprived of its shine
