I love linen and satin...
Talbots makes great linen dresses, especially if they button in the front, with satin linings. Also, Adrianna Papell!
Liz Claiborne coats are good.
I stay away from tween brands and stuff from Platos. I love ebay and vintage stuff. Rafaella is great, as is Norton McNaughton.
There's something amazing about crisp linen that you can wrinkle and love and then iron it and then wrinkle it again!
Or are you just satin-only? (There's also degrees of satin--acetate is the nicest, then rayon, then poly, then nylon (cheapest, mainly from catalog brands like Chadwicks/Adolfo Studio. The nylon is shiny but it's very hot and not as good as good acetate)).
